J.B. Weld question
Gunny
09-08-1999 14:09:49
The bottom of my burn barrel has rusted away and fallen off... I want to JB Weld a metal grate to the bottom of it... will JB Weld hold up and be able to withstand the high temperatures of a burn barrel? Does anyone have experience in such a matter? Keep yer powder dry, Gunny, USMC
Ray Nunemaker
10-04-2001 14:16:55
 Re: J.B. Weld question in reply to Gunny, 09-08-1999 14:09:49
At what temperature does J B Weld melt? We have a customer that we put J B Weld around a pipe plug and then over the top of the plug. They want to know what process we will use to remove it someday when they need into the port cavity?
Mac
12-11-2000 19:33:00
Some Einsteins have repeatedly beat up my vicious mailbox. Itis wrought iron and they broke a large piece off. I J.B.Welded it back (after cleaning with acetone and alcohol), it glued nicely. Week later, Einstein was back. The J.B.Weld did not hold up to 3900 psi/lbs.as stated on back of pack as mailbox broke exactly where it did before. Why????
P.S. They used a wooden stick which broke.
Signed, Mac
stan
04-18-2000 01:12:28
well j-b weld work on aluminun oil pan with a small hole in it
cj
09-10-1999 08:44:16
I'm with them. We use an old axe to chop a few hole in the bottom. Takes out a lot of stress too! I like the idea of shooting the holes too. The rebar thru the bottom would stand up a loooong time.And with the price of JB weld you could afford to haul to the dump(I mean sanitary landfill, no waste containment site, no ...oh you know what I mean.Fire when ready!
Wolfman
09-09-1999 09:37:54
Whenever I get a new barrel, we set it down in the field a ways, get the rifle out and fill the bottom full of holes. The barrel lasts a good long time.
g.c.
09-08-1999 18:26:51
It's your barrel,so have as much fun with it as you can stand, but why don't you poke or drill holes along the bottom and run some reinforcing rods through for a grate? It,s a burn barrel,not the space shuttle!
bentorbroke
09-08-1999 17:26:59
Hi, JB Weld is good for a lot of things. It is not suitable for the application you mentioned. It is a epoxie based material with a metal and/or fiberglass filler. It will melt and burn at elevated temperatures. It does hold up reasonably well in applicatons up to about 250 degrees F. Good luck, have fun, bentorbroke
Leon
09-08-1999 15:51:36
Gunny Don't want to sound like a smart elic but
how many tubes of JB weld would it take vs a new
barrel. In my area Barrel's are $5.00.
terry
09-25-2000 15:42:10
 Re: Re: J.B. Weld question in reply to Leon, 09-08-1999 15:51:36
can you use jb weld on exhaust
Zach
04-24-2000 15:31:48
Hey Gunny, I do agree in a way with buying a new barrel. There about $5.00 here in our area, but if you're like me you like to experiment. I love JB Weld. I have the two tubes of it in my toolbox at work, I'm about to buy some for home now when I leave the library. I used it one time to repair a gas tank on my pushmower. The fuel take came loose, rattling against the cooling fins on the engine creating a crack. JB Weld fixed it good as new. I do heating and air conditioning work. One day this past week the framework in a supply air register in the ceiling broke. JB Weld fixed it up good as new. Good luck my friend. -Zach
Carl West
05-21-2002 16:50:57
 Re: Re: Re: J.B. Weld question in reply to Zach, 04-24-2000 15:31:48
Zach, I have a leak in a tractor gas tank, and have been advised that gas will eat through JB.
You seem to have good luck in using it.
How long ago was the leak repaired??
Carl
vern munster
03-22-2002 15:02:01
you guys are a bunch of gooooo ooooo ooooo oooofs
