Teflon oil additives for engines
bentorbroke
09-02-1999 22:45:16
Does anyone have any good (or bad) experiences to share relative to the use of oil additives that contain teflon for gas engines. Are any of the brands better or lower cost, etc.
Dieseldog ONT,CAN
02-12-2001 14:45:25
 Re: Teflon oil additives for engines in reply to bentorbroke, 09-02-1999 22:45:16
Bent dude If your looking for a legitimate Teflon oil additive check out Tufoil at www.tufoil.com.This product holds patents,Gunniess records and has been government tested.I have personally used it to cure or limit wear or noise problems in engines,transmissions,transfer cases,and differentials.I swear by it and its found at most major auto parts stores. Good Luck Dieseldog!
mike daniels
02-07-2001 17:33:33
uh oh --i have used this stuff-----how do i negate the bad effects it can have?if it clogs a passageway-how do i unclog it ?
Jerry
10-03-1999 08:09:13
Every engine that I have torn down after teflon was added feels like sand welded to the block above and beside the rod and main bearins. Both of the Perkins diesel engines that it was tried in here developed a hell of an oil leak at front seals, and developed more blow by from vent tubes. Like the other post, it took several oil changes for the leaks to slow back down, 1 didn't stop leaking, and 1 did.
Otis
09-18-1999 19:49:08
Additivives are just a waste of money and may be darn right be bad in certain situations. Todays motor oils are just too good and some of the synthetic blends may be worth the extra $.
Paul R
09-03-1999 05:47:08
I tried some. Two of six engines blew within 2 weeks after adding the miracle lube. These two engines were worn quite a bit but I usually get much more service out of engines.
I would sooner buy a good used bridge than a pan protector for my motor again. I've heard that Dupont doesn't recommend it either. If I want to spend some extra mony I'll spend it on some synthetic blend oil from a major oil maker.
Just my two cents worth.
I take it back!
09-03-1999 06:04:28
 Re: Re: Teflon oil additives for engines in reply to Paul R, 09-03-1999 05:47:08
Correct me if I'm wrong but it doesn't even protect pans hence the invention of the plastic spatula. It only keeps your breakfast from sticking. When engines moving parts are all soft plastic I'll try it again.
Paul R
Louis G
09-06-1999 23:51:39
 Re: Re: Re: Teflon oil additives for engines in reply to I take it back!, 09-03-1999 06:04:28
Paul go to www.ftc.gov then click on search. Type Slick 50 in the search for box. It will have a world or information on numerous smoke and mirrors additives. PTFE in not good in the crankcase of your engine. Nutz & Boltz, a trade magazine, has done numerous reports on PTFE....save your money.
www.justicebrothers.com
"America's Brand�for Quality"
In the automotive business for over 50 years. The world's finest and most complete automotive/industrial chemicals.
pete-Tex
09-09-1999 06:49:06
 Re: Re: Re: Re: Teflon oil additives for engines in reply to Louis G, 09-06-1999 23:51:39
Tried Slick 50 once. (77 ford 460) Rear main started leaking, finaly quit leaking 3 oilchanges later. NEVER AGAIN!..
