Where can I get a long 4mm drill bit?
Robert Lause
09-02-1999 08:09:41
I need a long (< 15cm) 4mm drill bit for cleaning piping. Anyone know any manufacturers who make a drill bit this length.
Regards
Neal
09-15-1999 11:31:22
 Re: Where can I get a long 4mm drill bit? in reply to Robert Lause, 09-02-1999 08:09:41
MSC Industral supply has 5/32 extension drills which is just .0013" smaller. The 6" drill is #01000108 $1.35 and the 12" drill is 01010107 $3.69. Phone # 1-800-645-7270
Good luck
Neal, P&T Machine
big fred
09-03-1999 16:52:35
I would suggest an industrial supply house or someplace that sharpens industrial bits on contract. A sharpening house may have bits which no longer meet their customers' specifications, and sell them at a very low price. An industrial supply house would probably only sell wholesale, so you may have to sweet talk your friendly local machinist into getting it for you.
Bob T
09-03-1999 15:20:24
Don't know about the bit, but to clean piping (like EGR line) that has bad stuff clogging it, I use a piece of cable (like old speedometer cable or wire rope). I hold the end together about 1/2 inch back by wrapping with wire or heat shrink tubing or some such. Allow the 1/2 inch of end sticking out to fray out to make a brush. Then I use an electric drill to run it in the pipe. It helps to look at which way the wire rope is laid (left hand or right hand) and then use fwd or reverse on the drill so the rope doesn't try to come apart. Hope this helps.
