Readyheater
Jon Lancto
08-31-1999 08:48:21
I have a Readyheater 55K BTU which I just replaced the motor in. Now it wont ignite. It has a good arc on the plug (which is alligned and gapped correctly) and is spraying fuel into the ignition chamber. Ive checked the fuel filter and the pump looked fine when i replaced the motor. What should i check next?
Jim Duralia
12-15-2002 20:32:32
 Re: readyheater in reply to Jon Lancto, 08-31-1999 08:48:21
I am trying to locate the readyheater website to obtain parts and a manual for a 150K BTU kero "torpedo" style heater. Does anyone know the name of the cos. website?
Thanks,
Jim
Please reply to my e-mail address.
bollweevil
01-23-2003 06:35:44
 Re: Re: readyheater in reply to Jim Duralia, 12-15-2002 20:32:32
Try this link. The last time I ordered parts I got fast shipment.
bollweevil
01-23-2003 06:41:32
 Re: Re: Re: readyheater in reply to bollweevil, 01-23-2003 06:35:44
sorry, the link failed, try this
Link
Debbie Kohut
04-12-2000 10:42:41
I live in NE PA & don't know where to get my Readyheater repaired. Does anyone know some information to help me??? Please e-mail me at CheckerDeb @aol.com Thanks!!
RPV
08-31-1999 10:29:18
This happens on mine sometimes and I have to pull out the plug and dry it off and clean it up. This also happened to me once when I used dirty diesel fuel instead of clean kerosene. How clean is your fuel?
jeff giesie
04-09-2000 20:01:02
 Re: Re: readyheater in reply to RPV, 08-31-1999 10:29:18
I have a 30k btu vent free ready heater for my garage, the pilot light lights fine but when I go to swith it to high or low it wont Ignite the burner.
charlie
09-05-1999 19:11:24
you could have an air flow problem.try removing the shrowd and see if it will ignite. another problem could be pump pressure.refer to your owners maunual on how to check it. good luck .
