Help! John Deere lawn tractor stuck in gear
Eric
05-29-1998 08:42:50
Old John Deere lawn tractor is stuck in 2nd gear. Does anyone have any suggestions on how to fix it.
farmer
05-29-1998 11:31:19
 Re: Help! John Deere lawn tractor stuck in gear in reply to Eric , 05-29-1998 08:42:50
: Old John Deere lawn tractor is stuck in 2nd gear. : Does anyone have any suggestions on how to fix it.
Eric:
Try posting it to the new garden tractor group listed under
"Tractor Cafe" , maybe somebody there has had this problem.
Those little trannies get awfully busy inside, I think I would rather
rebuild the automatic on my truck. - good luck
Jim WI
05-29-1998 10:45:32
I had a JD 112 that was stuck is second and also had the transmission locked up by also being in another gear at the same time. Is this your problem? (If so, the rear wheels won't turn no matter what you do.)
The only real solution is to disassemble the transmission and replace any damaged parts. The transmission is not very complex -- just hard to get to since you have to take so much apart. Parts are not cheap either, but what do you expect on a JD? (Cheap tractors have more inexpensive parts that you replace more often.)
