HELP! BACKHOE HYDRAULIC FLUSH
Doug (WA)
05-28-1998 11:47:07
I have an old "Hydreco" back hoe on my Ford 9N that contains terrible looking hydraulic fluid that I want to flush out and replace. I have cycled about 10 gallons of new thru, after draining the tank. The new fluid gets also milky looking in short order. THANKS
How do I get it all out? Is there a need, or a way to bleed the lines after installing new??
Ryan Perkins
06-02-1998 09:33:00
 Re: HELP! BACKHOE HYDRAULIC FLUSH in reply to Doug (WA), 05-28-1998 11:47:07
yes, to the inlet for the new fluid, attach a compressor, and at a low to moderate pressure, you can force some af the old fluid left behind, and make sure you are using the right type of oil.
