Wire welder
Leon Miller
08-07-1999 18:22:07
Need help deciding on a home use wire welder.
100 amp would probably do what I would want it to do but would possibly want argon capabilities?
I have a cracker box and torch already.
I have heard some wire welders have problems with wire feed. What do I need to look for in a decent wire welder and where do I go for best prices..Thanks.
steve lusk
02-22-2000 06:08:20
 Re: wire welder in reply to Leon Miller, 08-07-1999 18:22:07
I have a 225 amp wire feed welder.What I want to know is how heavy of an extention cord I need to run 60ft.The name plate says it draws 40 amps@230 volts.Thanks.
MWill
09-10-1999 19:39:41
Hey Leon why don't you get that millermatic, at least you'll already have your name on it, I know which one I would get if my name was lincoln.
Paul Fox
08-08-1999 04:33:58
I've been very happy with my Lincoln SP-130T. It's a small unit for light work up to 3/8", and I use Stargon (Argon and Carbon Monoxide, I think) as a sheilding gas.
No problems at all with feeding wire, or anything else, for that matter.
I got mine at a local automotive parts and tools jobber, but you might be able to get a better price at a big Home Center or Northern Tool or somewhere like that.
Leon Miller
08-08-1999 09:30:25
 Re: Re: wire welder in reply to Paul Fox, 08-08-1999 04:33:58
Thanks Paul
I have been looking at that unit as well as the Millermatic 130. How long have you had your unit?
How large are the gas bottles? Are they rented or purchased and approx what is the cost of the gas?
This is a hobby thing with me and I don't want to get in over my head.
Paul Fox
08-08-1999 12:21:07
 Re: Re: Re: wire welder in reply to Leon Miller, 08-08-1999 09:30:25
I've had the rig about 6 years. Hobby level for me, too. I use it for light fabrication and maintaining small equipment. It came with a 1 year rental on the smallest size bottle made. I sucked that up pretty quickly, and when I exchanged it, I got a 5 year lease on what the supplier called a "Q" size bottle. It's about 6" in diameter and 30" tall, lasts me about 3 or 4 months at the rate I use it. Cost just a whisker over $20 the last time I had it filled. Lease on the bottle is $55 for the five years.
leon mller
08-08-1999 20:07:34
 Re: Re: Re: Re: wire welder in reply to Paul Fox, 08-08-1999 12:21:07
Thanks Guys for the response.
Looks like I need to purchase the 130 in a Lincoln or Millermatic.
Will now start price shopping.
Jeff
08-20-1999 03:45:16
 Re: Re: Re: Re: Re: wire welder in reply to leon mller, 08-08-1999 20:07:34
Leon:
Just purchased a Lincoln SP-175 Plus, $695.00. Q size bottle 5 year lease $115.00, refills of Star gon, 19.00, 11lb. spool of wire $21.00.
Already had regulater. Plus tax.
It is a 220 volt model, however, was about $150.00 more than 110 volt model and I have more amps.
Bought it from local welding supplier in my area.
So far I'm very pleased with it, a little more than I wanted to spend.
Good Luck and good welding
Steve
09-03-1999 06:22:49
 Re: Re: Re: Re: Re: Re: wire welder in reply to Jeff, 08-20-1999 03:45:16
I have been in the welding field for over 20 years and can say that you get what you pay for in wire welders. If you want a small 110 volt machine the Miller or Lincoln is a good choice. I have sold Miller for years but Lincoln is also a fine machine. No matter what you buy look for these features. Buy a machine with at least 130 amp output, built in gas solenoid, steel drive wheels and idler, and a remote contactor built in. Without the remote contactor the wire is hot all the time and you'll flash yourself trying to get the gun in position. You might even get shocked. As far as gas is concerned, you don't need it. You can use an open arc wire instead. The advantage is being able to weld dirty and outside in the wind. The downside is that you will get a little smoke and a little more spatter. You also need to change polarity on the machine. Open arc wire costs slightly more too but is much more suited to maintenance welding.
