Need info -post hole auger
dave
05-23-1998 11:35:42
Hey boys and girls ! I borrowed a 3 point post hole auger from my boss, it came with the house he bought so we don't know beans about it ! Is there different augers you can buy to do different types of holes ?, I looked in my C.T. catalog and they offer several different replacement augers,-single-flight auger, double-auger, they both come with points and cutting edges. I think my auger is worn out from years of use, it's tapered from about 8" at the top down to 3" at the bottom, and has no place to put on new cutting edges ( which C.T. also sells ) I don't know beans about this thing so any and all help would be appreiciated !!!!! !
dave
Terry
05-29-1998 08:45:18
 Re: Need info -post hole auger in reply to dave, 05-23-1998 11:35:42
: Hey boys and girls !
: I borrowed a 3 point post hole auger from my boss, it came with the house he bought so we don't know beans about it !
: Is there different augers you can buy to do different types of holes ?, I looked in my C.T. catalog and they offer several different replacement augers,-single-flight auger, double-auger, they both come with points and cutting edges.
: I think my auger is worn out from years of use, it's tapered from about 8" at the top down to 3" at the bottom, and has no place to put on new cutting edges ( which C.T. also sells )
: I don't know beans about this thing so any and all help would be appreiciated !!!!! !
: dave
Dave, sounds like the auger is just worn out, must have been a lot of rocks or a lot of years use. Recommend replacing with an auger just a little bit bigger than the biggest post you'll be putting in. Most come as 6" or 8" diameter but you can get them bigger.
Also be very careful using an auger, don't allow anyone to stand near the auger when you use it, and the operator needs to stay seated on the tractor. Be safe and have fun.
Terry
dave
05-30-1998 19:56:09
 Re: Re: Need info -post hole auger in reply to Terry, 05-29-1998 08:45:18
: : : Hey boys and girls !
: : I borrowed a 3 point post hole auger from my boss, it came with the house he bought so we don't know beans about it !
: : Is there different augers you can buy to do different types of holes ?, I looked in my C.T. catalog and they offer several different replacement augers,-single-flight auger, double-auger, they both come with points and cutting edges.
: : I think my auger is worn out from years of use, it's tapered from about 8" at the top down to 3" at the bottom, and has no place to put on new cutting edges ( which C.T. also sells )
: : I don't know beans about this thing so any and all help would be appreiciated !!!!! !
: : dave
: Dave, sounds like the auger is just worn out, must have been a lot of rocks or a lot of years use. Recommend replacing with an auger just a little bit bigger than the biggest post you'll be putting in. Most come as 6" or 8" diameter but you can get them bigger.
: Also be very careful using an auger, don't allow anyone to stand near the auger when you use it, and the operator needs to stay seated on the tractor. Be safe and have fun.
: Terry
Thanks for the info Terry, I bought a 12" double flight auger from C.T. today , installed it and started drill'n in the garden just to try it out, The thing now works like it should. dave
