Continential G176 Engine
Kenneth A. Gasc
07-09-1999 21:22:26
Looking for help I have a Massey Ferguson 165 with a continential G176 engine. The engine had very low (less than 5 PSI) oil pressure. I pulled the engine and had the crank turned and cam bearings installed. I reassembly the engine with a rebuild oil pump, new rod & main bearings,and new rings. The engine runs good but it still has very low oil pressure (less then 10 PSI @1500 RPM) I did not trust the original oil pressure guage so I check the pressure with a new one. I know it is impossible to trouble shoot an engine thru the internet, but maybe someone might know of something that is common to the G176 Continential Engine that might cause this problem. Any help you can provide will be greatly appreciated.
Ken Gasch
Mike
07-14-1999 15:35:45
 Re: Continential G176 Engine in reply to Kenneth A. Gasch, 07-09-1999 21:22:26
Don't recall if the engine you have was one we used in the patch, but you might check and see if the engine has a built in pressure relief somewhere that may be stuck in the open position.
Another thing I gotta ask, you did clean the oil pickup screen/tube assembly when you had the engine apart didn't you? If not, you could have a restricted suction.
