Steam Cleaner questions
John F
06-18-1999 18:20:49
I just purchased a steam cleaner. It fires up ok
, doesn leak anywhere. It's a Northeast model
150. I have 2 questions. What type of wand
should it have...it appears to have a pressure
washer nozel on it, with a fan spray nozzle.
My 2nd question concerns the pressure releif
valve. It appears to be adjustable. I have know
idea what it's set for. I think I'll replace
it. What releif pressure, should I use?
db
07-01-1999 06:21:06
 Re: Steam Cleaner questions in reply to John F, 06-18-1999 18:20:49
the relief valve is to ajust the pressure. to lower or raise the psi. The fan spray is in degrees of angle, also may be replaced they do wear out. You must have a wand that is compatable to your system. For heat. Find a parts dealer
Beth Kelly
04-19-2000 16:35:00
 Re: Re: Steam Cleaner questions in reply to db, 07-01-1999 06:21:06
I am looking for a small steam cleaner for use in auto detailing. Haven't had much luck. Please help!!!! Thanks
martin carp
03-02-2000 16:25:26
Looking for a piece of equipment that would function as an undercarriage washing device for heavy truck that would attach to a steam cleaner.
This unit would allow steam cleaning the underside of a vehicle without the need to lift the vehicle. If you know of a company that can fill the need please leave there name and e-mail.
Paul Fox
06-19-1999 03:40:46
I doubt you need to mess with the relief valve, or replace it. With liability suits being what they are, the manufacturer no doubt set it well below any question of problems.
If you think it's been fooled with, check the book or call the company.
