Positive ground systems
Bryan Heinle
06-03-1999 15:33:00
I am trying to learn why positive ground electrical systems were used in many older pieces of equipment. What was the advantage(s) of the positive ground system as opposed to the more popular negative ground system. There must have been a reason why engineers chose positive grounding. Anybody know, or remember?
Eric
06-11-1999 09:03:35
 Re: Positive ground systems in reply to Bryan Heinle, 06-03-1999 15:33:00
The flow of electrons goes from negitive to
positive. Think obout it for a minute the output
from the battery is on the shielded side in a positive ground system.
Mark
06-09-1999 10:01:28
Some of the negative ground use was used to keep customers from installing components that weren't made by the manufacturer. The companies liked having control on the parts that could be used in their products. That was part of the "logic" It is much like the computers of today. Companies tried to make components that only they could sell to customers, but when customers quit buying they had to go to a standard system.
ronm
06-06-1999 08:34:25
As of the late 80's Mack was still using pos. ground on trucks that were set up from the factory to have a water tank on them. They claim it reduces electrolysis in the tank and other parts in contact w/ water. I ran into this in the process of installing a two-way radio in a Mack.
DC Dale
06-04-1999 22:00:49
When I was in Hi School inthe late 60's I was taught pos. ground caused less corrosion at the ground onnections, which I have never observed in actual practice. White Motor Trucks continued pos ground clear into the 70's..... ....
