Are there 1/32 discs available for a 4 1/2 grinder?
tom
05-28-1999 11:11:32
I have a standard 4 1/2" grinder that I use for grinding welds, etc. Does anyone know if there are 1/32" thick abrasive discs available? I have been using an air cutoff tool for slicing through sheet metal for years. Eventually I run out of air and have to wait for the compressor to build. It would be much easier to slap a disc into my grinder and go to beat hell. (and much cheaper than buying a larger compressor) Any help is appreciated.
DC Dale
05-28-1999 19:39:02
 Re: Are there 1/32 discs available for a 4 1/2 grinder? in reply to tom, 05-28-1999 11:11:32
I believe I saw them in the new Eastwood Catalogue. www.eastwoodco.com. Watch your wallet , sometimes their prices are kinda steep.
JMc
05-28-1999 14:05:57
yes they make a cut off disc for a 4 1/2 grinder not sure if there 1/32 but are very thin , you will have to take gaurd off to use the cut off disc they come in 5/8 and 7/8 arbor I prefer the 5/8 . Metabo makes these discs there are other brands . these discs are very popular where they fit stainless steel pipe because you cannot torch stainless go to a welding supply place they ought to have them I have seen these averitised in harbor frieght catalog I work at a sugar factory in southern Idaho and we use these discs every day be very carefull my coworker cut into one of his tendons good luck
