H FARMALL
Ronnie Cosper
05-25-1999 06:33:49
Just got one. How much oil does it hold? How do you know when it is full?
TomH
05-25-1999 16:01:04
 Re: H FARMALL in reply to Ronnie Cosper, 05-25-1999 06:33:49
There is a drain plug on the bottom of the pan, and two valves on the side, one about an inch higher than the other. The manual says before every day of work you should open the lower valve and drain out oil until it stops, then close it and open the upper valve and fill until oil starts to drain out of it (filler cap is on the right side below the generator). I think the total amount is about 6 quarts. By the way, you're welcome to visit the Farmall discussion group.
