Can power steering and/or transmission pumps be used as hydraulic pumps??
Dave
05-16-1999 07:34:42
Can power steering and/or transmission pumps be used as hydraulic pumps?? I would like to make a couple items such as a small acreage tilt trailer and a wood splitter. Can anyone tell me if these items have the volume and the power and is there much to adapting the hoses?
Charlie Okla
05-18-1999 22:59:45
 Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to Dave, 05-16-1999 07:34:42
Transmission pumps are part of the case. Northern(northern-online.com) has good pumps cheap. And more important, they have the fittings and tanks.
john d.
05-18-1999 06:26:46
Power steering pumps generate VERY low volume.
Dave
05-18-1999 17:43:24
 Re: Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to john d., 05-18-1999 06:26:46
Would a transmission pump be feasible??
farmer
05-26-1999 15:24:09
 Re: Re: Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to Dave, 05-18-1999 17:43:24
Go find you a junk self propelled combine (I know a Deere 45 will work) with a belt driven pump. It is a high capacity system and has the tank, fittings, valves and cylinders all right there and matched to each other. Combines get few hours compared to tractors so the hydraulic systems are usually the best thing on a junk one.
Dave
05-28-1999 12:51:17
 Re: Re: Re: Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to farmer, 05-26-1999 15:24:09
Thankyou everyone for the valuable information. If farmer is still there, could you tell me if a 5 h.p. or 8 h.p. engine is adequate to run the combine hydraulic pump?
BOB
06-29-1999 11:57:01
 Re: Re: Re: Re: Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to Dave, 05-28-1999 12:51:17
Yes , use a chevy. P/S pump and remove the cover, and you can use a 1/4 pipe tap and fittings.
the pump will pump. I know of 1 used on a wrecker , but it had a large ram and picked up SEMI,s.
and 1 used on a log spliter.
also hay fork, using a old modle ford starterw/ a long shaft and put a pulley for 12 volts
you have to have a tank and some valves, for the return. but pump,s are plentyful
Ron
04-30-2000 18:01:43
 Re: Re: Re: Re: Re: Re: Can power steering and/or transmission pumps be used as hydraulic pumps?? in reply to BOB, 06-29-1999 11:57:01
Bob,
Got the wrong e-mail address on the prior.. it should be [email protected] Thanks
Ron
04-30-2000 17:35:22
Bob,
On my tractor, the engine driven hydraulic pump starved and froze up, shearing the pump's drive shaft (not the key unfortunately). Replacements are looking like apx $300. How viable is it to throw a automotive P/S pump on, and go with that?
4/30/2000
