Coleman PW85-1500 Pressure washer
George Adamovic
05-08-1999 13:48:09
Hello all!
I inherited a PW85 pressure washer without an instruction book. I noticed there are three different oil filling points. I think it's a 4 cycle engine. What oils does it take?
Thanks for any help.
George
Rod Slagter
04-15-2001 07:31:47
 Re: Coleman PW85-1500 Pressure washer in reply to George Adamovich, 05-08-1999 13:48:09
I too have a pw85-1500 and I need a pump rebuild kit. WHere can I get one and how much?
AHCrook
09-30-2000 16:27:53
Where can I order Coleman Pressure Washer parts? My husband bought it from Lowe's, but they no longer carry it.
bob mchenry
03-15-2000 05:51:34
I own a pw80 1300 coleman pressure washer and would like to obtain an owners manual or service manual. During use I recently noticed that water is mixing with my oil and coming out the breather tube on top of the pump. I know it is not supposed to do that as it never did that in the past. Any and all information on how I can repair this problem would be greatly appreciated. Thank you for your help. Please contact me at [email protected]
Sincerely,
Robert A.McHenry
Rob
05-09-1999 22:14:28
What Brand of engine? h.p.rating?
If it's a 4 cycle, (more than likely) it takes sae 30 wt motor oil.
dale
06-10-2004 18:06:39
 Re: Re: Coleman PW85-1500 Pressure washer in reply to Rob, 05-09-1999 22:14:28
need the end of the pump where the hose connectsmine broke off where the thread is does anyone know where i can get one?
Jak
03-17-2000 15:00:18
I also have that washer, but the spray comes out too fine, even opening the wand fully. It takes me forever to clean a driveway with it. Anything I can do?
db
07-01-1999 06:46:17
2 of the oil ports are most likly the crankcase it just has two holes for diffront applicacation THE OTHER ONE IS FOR THE PUMP USE NON DETERGENT OIL
geri payne
06-22-2000 20:10:24
 Re: Re: Re: Coleman PW85-1500 Pressure washer in reply to db, 07-01-1999 06:46:17
Coleman playmate pressure washer 1500 psi gas engine need alumin head for pump
geri payne
06-22-2000 20:13:25
 Re: Re: Re: Re: Coleman PW85-1500 Pressure washer in reply to geri payne, 06-22-2000 20:10:24
Coleman playmate pressure washer 1500 psi gas engine need alumin head for pump Where would I find this part
JOE STEWART
03-20-2000 07:24:01
LOOKING FOR PARTS FOR COLEMAN POWERMATE 1500. NEED PUMP OUTLET P/N OFF PART IS 5.20.301.00 1 ALSO NEED WAND AND HOSE. NEW OR USED
George Williams
06-21-2003 20:07:33
 Re: Re: Re: Re: Coleman PW85-1500 Pressure washer in reply to JOE STEWART, 03-20-2000 07:24:01
Having trouble separating pump from engine( 5hp B/S ) Any tips appreciated. My unit has pin holes in pump head and prices from Coleman are out of sight on parts. Does anyone know of a replacement pump that will fit? Has anyone found a service manual? Any input would be appreciated. I am told
Coleman had problems early on with their pumps.Have talked to my local dealer and he agrees that Colemans prices for parts are unreal.
i.e. new pump $485.00.Unit has been good so far and would like to repair without buying the farm.
Help.GHW
