What thickness steel can gas welder handle?
Douglas Stockma
05-08-1999 04:26:34
Greetings:
Sorry for such a basic question. Can a gas welder be used to weld 1/4-3/8 inch steel? Most weldors recommend that if you only have one welder, make it a gas welder. I am playing with the idea of getting a torch welder. I hope to create and repair farm implements. Is a torch an adequate tool for the job? I suspect a large 220 V stick welder is more appropriate, but electricity access will be limited. Thanks for any guidance the experts in this group can offer.
Douglas Stockman
Rochester, NY
[email protected]
Steve Hansen
05-13-1999 08:58:21
 Re: What thickness steel can gas welder handle? in reply to Douglas Stockman, 05-08-1999 04:26:34
Douglas,
I like to spend other people's money and giving advice in forums like this is a great way to do it.
In most welding shops today, you do not see any gas welding or brazing going on at all. The wire welders available now are so good they have made gas work obsolete. The only thing gas is used for is cutting.
Gas welding supplies are expensive and production is slow. Unless you have a second set of tanks you always run the risk of running out in the middle of a job.
You indicate your resistance to arc is because you have limited electrical service available. If you have any service at all you should be able to upgrade. The cost should not be too bad. I recommend you look into this option before you rule out an arc welder.
A good arc welder requires a dedicated 50 amp 220 circuit, the same as a kitchen stove. This may be more than you have in your shop right now but in the world of electricity it is not much. I strongly suggest you upgrade your shop's service now so you can use the right tools in your equipment fabrication and other hobby work.
Most "experts" recommend 200 amp service for a fully equipped "dream" shop. Assuming your shop is in an out building, I think you can get by just fine with a 100 amp panel, the same as most houses built in the 50s and 60s. Your actual draw will be much less most of the time. However, a 100 amp panel will give you a lot of breaker space, handle "peak" requirements, and they are available used if you look around (I purchased one for my cabin at a yard sale for $12.00 and a friend gave me the one I am going to use in my new shop for free). In addition to a circuit for your welder, you are going to need circuits for drill presses, grinders, general duty outlets, and don't forget an air compressor. You may not have all of these tools now but you will acquire them if you keep fabricating. With a capable panel in place you can run circuits when you need them.
You will need to connect to your power provider. If your house has 200 amp service you should be able to run to your panel. If you do not have 200 amp service it may be necessary to run a new service from you power provider or to connect in at your meter base. Due to variables, I am not going to discuss options here but please feel free to e-mail me if you like. I am not an electrician but I have some experience in this area and none of this is very exotic.
Rob (Mn)
05-10-1999 21:42:35
Thinking hard and trying to recall the dimensions of the stuff I gas welded back in pre-vocational welding class (in high school) and if I recall correctly you should be just fine at 1/4 to 3/8ths. Just do a bunch of practise welds on scrap and then try and break 'em in a vice. If it breaks on the weld you blew it. Anyway, that's how I learned :)
Tom from Ontario
05-10-1999 09:40:40
Douglas: What do you mean by a gas welder? Gas-Shielded arc or torches with welding head? If I could only have one welder, it would be a 240 volt stick (SMAW) welder. Low cost, versatile, cheap to run, a good one can have a TIG attachment put on it, etc. I would not have a MIG welder unless I was working exclusively with new, light gauge material. The big advantage there is sheer speed. Tom
Douglas Stockman
05-10-1999 09:45:36
 Re: Re: What thickness steel can gas welder handle? in reply to Tom from Ontario, 05-10-1999 09:40:40
I am referring to acetylene torch with welding tip. We may not have easy access to a 240 V line so the large stick welders may not be an option.
Douglas Stockman
Rochester, NY
Mike
05-14-1999 16:17:36
 Re: Re: Re: What thickness steel can gas welder handle? in reply to Douglas Stockman, 05-10-1999 09:45:36
Seems to me that the steel mills are still using blast furnaces to produce steel which is then rolled down into thinner sheets and rolls (the thickest I've personally seen as a sheet or roll was about 4" thick) so it's not really a question of if the oxy acetylene torch will get hot enough to melt the steel, but of how thick a material and how much of it you want to work on.
An example would be to take a piece of electronic solder that is about 1/16" in diameter and melt it with a match (easy if it's 60% tin and 40% lead). Now try the same thing with the match and a block of the same type solder that is 6" square.
That's just to give you some perspective as to the size limitations you'll run into with the gas rig.
The acr welder will concentrate a very high amount of energy into a smaller area for faster welding due to the energy not being able to disipate in the time involved, where the gas torch has to be able to heat the entire "Thing" in some cases.
There are people that swear by both...
If you can scrape the money together, you might want to consider a portable engine driven welder which also can provide standby power for the house or barn in addition to a small gas outfit for cutting. If not, I'd personally go for a larger gas setup (that's what I actually did many years ago).
Paul Tweten
06-01-2000 23:50:51
 Re: Re: Re: Re: What thickness steel can gas welder handle? in reply to Mike, 05-14-1999 16:17:36
Hey guy. I think I know what you are asking. You don't want to rely on oxy/acet to hold together for a substantial amount of time or abuse that farm machinery requires. If you plan on repairing and fabricating any kind of implements I would suggest a welder/generator for any repairs in the yard or the hills I have an older one that I use all the time. A new one will be alittle investment but if you consider the money lost by down time because you broke down in bum#**# it is well worth it. The newer ones are capable of running a mig or a tig from with a simple hookup of the gun. Not to mention back up power if the power goes out.They all come with 110&220 outlets.In my oponion you can't go wrong with a gas or deisel welder. Shop around andyou can find them for about two to three grand mounted on a trailer. Add a set of tanks for cutting and a small air compressor and you will be set for a long time to come.
