Adding a solution draw tube to a pressure washer
Mark Gaza
05-08-1999 00:20:23
I purchased a pressure washer for $100 and it has no draw tube for solution. I looked but could not find a place to add one. Any help would be appriciated..
Ernie Krause
03-11-2001 16:23:11
 Re: Adding a solution draw tube to a pressure washer in reply to Mark Gaza, 05-08-1999 00:20:23
I am looking for an outlet manifold for a John Deere A25 pressure washer. Serial # 25000 +.
Rick
05-10-1999 19:09:24
Did you check on the HIGH pressure side of the pump? That is where it would be located if the unit was equipped.Check Northern Hydraulics for parts , excellent source of parts,
www.northern-online.com
