Home emergency generators [nat. gas]
steve mills
05-07-1999 18:03:30
it seems there ought to be a very small nat. gas generator available for homeowners w/ gas furnaces that have electronic ignition. all we need, to have heat, when the power is off is 110 volts/ 30 amps no transfer switch, no fancy bullshit, just go outside and open a gas cock, fire up the generator, go back inside and be warm. am i crazy or what?
TomH
05-07-1999 21:09:33
 Re: home emergency generators [nat. gas] in reply to steve mills, 05-07-1999 18:03:30
Generators are available that burn Natural Gas or Propane (Northern has a couple in the $1600 - $2000 range). You'll still need a transfer switch to take any circuits you are powering off the grid. A gasoline or diesel generator is more useful since you can use it away from the house for powering tools, etc. when an extension cord won't reach.
Robert (AL)
05-13-1999 17:02:14
 Re: Re: home emergency generators [nat. gas] in reply to TomH, 05-07-1999 21:09:33
I recently purchased a generator and need more info about transfer switches and safety tips.
Regards,
Robert
