Need help with Ford diesel
Bill Rogers
04-29-1998 15:25:54
My Ford 2000 3 cyl diesel is weak! I've replaced the fuel filters, drained the fuel tank, and added fresh diesel fuel with an additive to clean the injectors. Exhaust is excessive and white. What should I do next - valves, injectors, pump?
Don
05-04-1998 07:18:29
 Re: Need help with Ford diesel in reply to Bill Rogers, 04-29-1998 15:25:54
: My Ford 2000 3 cyl diesel is weak! I've replaced the fuel filters, drained the fuel tank, and added fresh diesel fuel with an additive to clean the injectors. Exhaust is excessive and white. What should I do next - valves, injectors, pump?
Chances are when a diesel is smoking white it is burning a little water. Does it smoke white all time or just briefly after you start it? It is a fair bet you have a blown head gasket. Hopefully that is all it is. Look in the radiator while the engine is running... any bubbles? Also, after it has set awhile open the crankcase drain plug carefully, any drips of water coming out before you get oil. Is the oil on the dipstick a creamey brown color? All indicate that is is getting water from somewhere, most likely the head gasket. Good luck.
Diesel Dan
05-01-1998 20:15:57
What should I do next - valves, injectors, pump? YES! Well maybe. White smoke indicates timing or incomplete combustion. Check pump to engine timing, then pull injectors run a compression test and have injectors rebuilt with new nozzles, not rebuilt tips. Pull pump as last resort. Poor compression will cause white smoke.
Regards,
DIESEL DAN (the pump man)
Indian Guy
05-04-1998 12:56:55
 Re: Re: Need help with Ford diesel in reply to Diesel Dan, 05-01-1998 20:15:57
: What should I do next - valves, injectors, pump? : YES! Well maybe. White smoke indicates timing or incomplete combustion. Check pump to engine timing, then pull injectors run a compression test and have injectors rebuilt with new nozzles, not rebuilt tips. Pull pump as last resort. Poor compression will cause white smoke.
: Regards,
: DIESEL DAN (the pump man)
Good to see Diesel Dan again! I thought you might have dropped off the world. I've got to be more careful, I just learned something. Thanks, Me
Tax payer
05-05-1998 02:51:37
 Re: Re: Re: Need help with Ford diesel in reply to Indian Guy, 05-04-1998 12:56:55
: : What should I do next - valves, injectors, pump? : : YES! Well maybe. White smoke indicates timing or incomplete combustion. Check pump to engine timing, then pull injectors run a compression test and have injectors rebuilt with new nozzles, not rebuilt tips. Pull pump as last resort. Poor compression will cause white smoke.
: : Regards,
: : DIESEL DAN (the pump man)
: Good to see Diesel Dan again! I thought you might have dropped off the world. I've got to be more careful, I just learned something. Thanks, Me
IT is terrible to see our tax dollars wasted by people who are should be helping our children but are playing with school computors. You know who you are, Indian Guy!!
Indian Guy
05-05-1998 14:19:34
 Re: Re: Re: Re: Need help with Ford diesel in reply to Tax payer, 05-05-1998 02:51:37
: : : What should I do next - valves, injectors, pump? : : : YES! Well maybe. White smoke indicates timing or incomplete combustion. Check pump to engine timing, then pull injectors run a compression test and have injectors rebuilt with new nozzles, not rebuilt tips. Pull pump as last resort. Poor compression will cause white smoke.
: : : Regards,
: : : DIESEL DAN (the pump man)
: : Good to see Diesel Dan again! I thought you might have dropped off the world. I've got to be more careful, I just learned something. Thanks, Me
: IT is terrible to see our tax dollars wasted by people who are should be helping our children but are playing with school computors. You know who you are, Indian Guy!!
Well I could apologize or try to justify my position, but I won't. Youd do have a point and I will concede that. I'll just keep my time on the net before and after school and during lunch. OK? Me
