Broken easy out
Roger
04-30-1999 18:22:40
How do you remove a broken easy out? I've got one in engine block. Also, why are they called easy outs? I've called them many names but never easy outs.
I thought it was only me
05-05-1999 12:27:26
 Re: Broken easy out in reply to Roger, 04-30-1999 18:22:40
I have had the same problem countless times. If ever a tool was badly named !!!! There must be a better way. Suggestions please.
Jerry
05-05-1999 19:18:25
 Re: Re: Broken easy out in reply to I thought it was only me, 05-05-1999 12:27:26
I quit using easy outs years ago and started using a left hand drill bit and left hand thread taps. Some times the left drill bit will remove broken bolt by it's self, if it does'nt, then I tap the hole left hand threaded, take 3-4" bolt with a nut screwed up on to it, screw bolt in about 2", run nut down against broken bolt & lock it down, now just turn the bolt you just added. It will screw out the broke one every time I have tried for about 10-12 years. I hope this helps, good luck to you. Jerry
Oh yeah, you can find the bits and taps and hardened bolts at a machine supply place, is where I get mine. They may seem expensive to some but I have saved some very delicate parts by doing like this, just use bit and all about 2 sizes smaller than broken bolt. See ya folks.
ANDY
04-22-2000 22:22:40
 Re: Re: Re: Broken easy out in reply to Jerry, 05-05-1999 19:18:25
THIS PRODUCT WILL CHEMICALLY REMOVE BROKEN TAPS DRILLS AND BOLTS WITHOUT DAMAGE TO THE PART!
TAPAWAY.COM
jack
05-07-1999 21:53:22
I like it! I've used the left handed drill bits but not the left threaded taps/bolts. I will try that. Thanks!
Jim
05-10-1999 23:39:43
 Re: Re: Re: Re: Broken easy out in reply to jack, 05-07-1999 21:53:22
If the part is small enought(head or similiar size) you can take to well equiped machine shop. They have a machine that pulverizes the bolt and/or easy out. Itdoesn't hurt threads either. This is an expensive process, however. The machine works by a beam or something,but its really slick.
Mitch Thompson
12-28-1999 18:43:17
 Re: Re: Re: Re: Re: Broken easy out in reply to Jim, 05-10-1999 23:39:43
Had a broken thermostat, bought a new one, and I broke the bolt off in the head, then I bought some easy out, and broke it off in the bolt. What do I do, What can I do?? I have been told not to try and drill the easy out for it is undrillable, and can mess up the engine.
Please respond Very Soon,
Thanks Mitch
JWL
05-05-1999 09:29:51
I usually weld a flatwasher to the top of the broken piece (bolt,tap,easyout,etc.) the weld a nut to the washer. let it cool completely and screw it out with your fingers.
cannonball
05-01-1999 19:31:32
don't know if engine block is in use or not...didn't say about where the ease out is at but if you are good enought with a torch you can blow the metal out of the cast engine block without hurting the threads in the block have done this a lot of times...must tap hole after blowing metal out...have messed up a few tips when there are no open ends on the broken bolt hole....usually drill shall hole first and then burn out metal....hope this helps..have nice day
R.M. in Ont.
05-01-1999 17:36:20
I have heard of using a die grinder or a Dremel
with a thin cutoff blade and very carefuly cut a
screwdriver slot in end of the easy out.
Of course if it's broke off down in to far this
won't work very good. The post below sounded like a good idea too.
If you can get down around it with a bigger hole
just retap for a bigger size bolt or helicoil.
Gotta have patience and a bit of luck.
jack
04-30-1999 23:55:05
As oops said... Anyway, if it is not too large an easyout, you sometimes can drill around it enough to loosen it. Sometimes even a spotweld cutter (looks like a small hole saw with a drill works. Other than that, hammer, chisle + time...
Oops
04-30-1999 20:21:45
