Lincoln SAE300 welder
DY
04-25-1999 06:51:04
I have a Lincoln motor-generator welder. I want to
change it from 440V to 220V. The tag is good enough to see how to hook motor wires, but not good enough to see how to hook the coil in the contactor. The coil will hum on 220, but not pull in the contacts. There is an extra wire coming from coil, I would like to know whether to switch to that wire or hook them both. I'd appreciate any help from someone with a book or better wiring diagram on welder.
Thanks
Dennis
carol
12-17-2000 07:05:38
 Re: Lincoln SAE300 welder in reply to DY, 04-25-1999 06:51:04
does anyone have a wiring diagram for a lincoln200 welder?
Joseph R
04-25-1999 20:18:19
You can find Lincoln online at www.lincolnelectric.com . You should send an e-mail to customer service explaining what you need. The e-mail address is [email protected] .
Good luck , Joseph R
welder
04-25-1999 08:27:26
call lincoln in Clevland OH. give them the code # of the welder they can tell you anything you need also year built
