Broke off bolts
AK
04-24-1999 17:35:38
How would I remove a bolt thats broken off in a piece of metal and I want to save the treads in the metal and then put in a new bolt.
Mike Aylward
05-02-1999 19:35:55
 Re: Broke off bolts in reply to AK, 04-24-1999 17:35:38
I have had good luck with the following method- heard about it several years ago and never would have believed it until I tried it. It works best if there is some bolt still sticking up where you can get ahold of it. Here goes:
1. Heat the bolt only first, then let it cool naturally.
2. Heat the area around the bolt AND the bolt at the same time.
3. While the bolt and surrounding area are hot, get an ice cube and put on the bolt ONLY. BE CAREFUL-WEAR GLOVES FOR PROTECTION.
4. Normally, if you can get a pair of vice-grips on the bolt, it will spin right out. No drilling required. Hard to believe, but it works. Try it.
JIm
04-28-1999 10:32:21
Drill a hole in the middle an weld it shut with 6013 then weld a nut on it ,and turn it out because it shrinks the bolt.
Bill
04-25-1999 14:01:05
All good advice, what I usually do though, is drill a hole in the bolt using a cobalt or titanium nitride bit. They cut better in higher
grade bolts, but use lots of lubricant. Then I
heat the bolt with a torch until it's red hot. Then, walk away and do something else until it's
completely cool. The expansion and contraction
will usually free up the bolt enough to make an
easy-out effective. If this fails, I get out the trusty die grinder. Good luck!
Aaron
04-24-1999 19:37:11
You can use an easy out. All you do is drill a hole (the size wil be given on the easy out) then screw in this thing that looks like a drywall screw with very coarse threads. They run opposite of the bolt threads, so the tighter you turn, the better the grip. You can also weld a nut on the end. The heat from welding will help loosen it up, as well.
Aaron
Wild Bill
04-25-1999 10:49:01
 Re: Re: Broke off bolts in reply to Aaron, 04-24-1999 19:37:11
If you are going to drill a hole use a reversable drill with a left handed bit. Sometimes you get lucky and the drill bit will spin that bolt right out.
Paul Fox
04-25-1999 04:01:57
What Aaron said is good advice, but:
Be careful with the easy-out. If the bolt was stuck enough to break off, it's usually stuck enough to break an easy-out, and then you have BIG problems.
If any of the bolt is sticking up where you can get at it, welding on a nut works fairly often. Also, before trying anything, get some penetrating oil, such as Kroil or Liquid Wrench, and soak the area good and tap firmly on the bolt off and on for a couple of days.
Better yet, read Roger Welsch's book "Busted Tractors and Rusty Knuckles"...he knows about everything there is to know about broken bolts! ;-)
Jim WI
04-27-1999 11:09:59
 Re: Re: Re: Broke off bolts in reply to Paul Fox, 04-25-1999 04:01:57
"Be careful with the easy-out. If the bolt was stuck enough to break off, it's usually stuck enough to break an easy-out, and then you have BIG problems."
I second that opinion.
You REALLY don't want to break off an eazy-out. (I still have terrible memories involving a valve cover bolt.)
Mike
04-26-1999 20:11:26
There's also another method that works, but "It Ain't Cheap" and is mentioned in case you have a one of a kind thingy that can't be replaced and money is not the issue (I had it done once on an engine block and the chair I was sitting in still looks like it was set up for pulling a gooseneck trailer).
It's called E.D.M. or electric discharge machining.
It really can burn an exotic alloy bolt out of a much weaker metal without damaging the weaker metal (seen it done or I wouldn't have believed it).
Mark
04-27-1999 19:04:40
 Re: Re: Re: Re: Broke off bolts in reply to Mike, 04-26-1999 20:11:26
In the navy we called them disintegrators. Kind of hard to find someone who has one though.
