Lincoln Shield Arc D23049 300 A welder questions
Truck
04-15-1999 11:10:11
Just picked up a portable welder as listed above. Does anyone know a source of manuals, etc. for above? There is no motor to power it, but I have a Pinto 2300 cc motor that is almost new.. Would that have enough power to run this beast?
There is what looks like a 110 v. plug, on the side of the connection box. The welder says 40 volts on the name tag.Could this actually be a 110 volt output? What kind of wattage would it put out? (Possible Y2K generator set here?????)
Thanks for your responses!
Mitchell L. Hale
06-14-2000 20:47:05
 Re: Lincoln Shield Arc D23049 300 A welder questions in reply to Truck, 04-15-1999 11:10:11
My lincoln welder has stopped arcing when I try to strike an arc and I have cleaned the brushes and checked the wiring as good as I could so could you help me to see what is wrong with it.
John Haile
02-28-2002 21:12:05
 Re: Re: Lincoln Shield Arc D23049 300 A welder questions in reply to Mitchell L. Hale, 06-14-2000 20:47:05
Chances are it has set so long it has lost it's polarity. Take a 12 Volt battery and re polarize
your terminals.
osunbor lucky
04-17-2001 13:40:29
please furnish me with price details of the following ;(1) sae 400d arc welder engine driven (2) sae 300 d arc welder engine driven and possible site in europe were it could be collected
osunbor lucky
04-17-2001 14:11:20
 Re: Re: Re: Lincoln Shield Arc D23049 300 A welder questions in reply to osunbor lucky, 04-17-2001 13:40:29
lincoln shield arc welder sae 300d and sae 400d should be engine driven
osunbor lucky
04-17-2001 14:09:59
osunbor lucky
04-17-2001 14:05:03
Joseph R
04-20-1999 19:28:34
You can contact Lincoln at www.lincolnelectric.com . They sent me an operators manual for my welder for FREE. I believe that they have your manual too.Good luck,
Joseph R
welder
04-16-1999 19:01:32
sounds like sae300? 40 v.@300amp output You need about 50hp at a governed 1800 rpm outlet on side 100V.DC only use only for tools that are rated for DC power thay are a good welder
