Airarc
DY
04-14-1999 05:38:02
Can someone give me about 30 second lesson on how to use airarc.
welder
04-16-1999 19:09:23
 Re: Airarc in reply to DY, 04-14-1999 05:38:02
airarc takes 250 amps to run 1/4 rod the more volts the better air pressure 90psi and up it will burn most anything including you
jim
04-15-1999 13:10:31
80-100 psi is fine.Electrode positive(reverse polarity)Make sure to have air holes down(between work and electrode)Force electrode into work softly,in such a mmanner as its not really touching metal,move forward slowly.
jim
04-15-1999 13:01:36
air preasure; 80-100psi is fine.make sure to have the air holes between electrode and material(down). use reverse polarity(electrode positive)hold at approx. 30-60 degree angle.use very light force ,light not really touching material.proceed at slow even rate.
jim
04-15-1999 13:00:46
john d.
04-14-1999 12:10:12
Set the air pressure for whatever the specs call for on the equipment you have, put the amps at 100 or so to begin with, and experiment on some scrap steel before trying to do anything critical. Aim it away from you at a 45 degree angle to begin with, and strike an arc as if you were going to weld. Be sure to cover every square inch of yourself with protective gear, and don't do this in the vicinity of flammable materials of any kind! These things work, but boy do they put sparks and hot metal into the air!
