Lab-Metal or JB-Weld ?Similar?
al
04-13-1999 18:47:04
What's the diff between JB and Lab Metal ?
Does one have an adv over another for diff applications?
Al
signman
04-15-1999 05:05:48
 Re: Lab-Metal or JB-Weld ?Similar? in reply to al, 04-13-1999 18:47:04
Lab-Metal comes in two formulations. One will handle heat up to 300 degrees the other upto 1200. Either of these is much higher than JB weld. You can machine or drill Lab-Metal. It also has a thicker base to assist in forming those odd shaped places. Tensil strength is also much better. Hoewever, be sure and use the Lab-solvent to clean the area before applying.
Wild Bill
04-14-1999 20:10:14
Always had good luck with JB, never tried the other stuff. Not much of an answer I guess.
