Rim Repair Suggestions Needed
Frank Tyson
04-07-1999 14:43:44
Removed tires and have some badly pitted rims. Also, valve stem area where the hole is supposed to be is greatly enlarged. Should the pits be brazed? Can I use something like J-B Weld? Are there patches available for the valve stem area? Would appreciate your help. Frank.
big fred
04-12-1999 14:44:49
 Re: Rim Repair Suggestions Needed in reply to Frank Tyson, 04-07-1999 14:43:44
I'd drill another hole for the valve stem and patch the existing oversize one. Just make sure you get the new one the same distance from the edge. For the pitting, I would remove and stabilize any rust, then give it a couple coats of paint.
Jim
04-09-1999 07:12:22
The way I would fix the rim is with a wire welder
and a 5/8 washer bent to fit or an 1/8" patch made for the hole.
Wayne
04-08-1999 02:44:57
Big if. My first guess is to replace it. But if you think it is salvagable try and weld a patch for the stem hole. as for the pitting I wouldn't do anything just clean and paint. Good Luck
