How to care for a deisel generator
Alex Dula
03-28-1999 20:08:26
I just bought a used 4 cyclinder Thermal King 460 VAC 3 phase 60 Hz. generator. I never have had a deisel engine before. It was last usedin 1993, it still had the fuel in the tank from then. It supprised me but it ran very well. I drained the old fuel. It has a 15 qt. oil tank and two fuel filters which I plan to change. I do not plan to use it much now. What do I need to do to keep it in good shape? It has about 3500 hours on it.Any info. on deisels would be appreciated. Thanks.
Alex
Mike
03-29-1999 08:01:18
 Re: How to care for a deisel generator in reply to Alex Dula, 03-28-1999 20:08:26
If the machine is going to sit for long periods between runs, you may want to think of putting a biocide in the fuel to prevent algie (algy ?) from growing in the fuel tank (the fuel you buy may already have it). This type of growth will cause acidic buildup, and ruin the injectors! The next item on my list would be filters, they're cheap insurance! If the unit is going to be for standby power for long term critical operations (ya can't shut it down till the jobs done), you may want to install multiple switchable filters (you can switch from one filter to another without shutting the thing off).
And run it every once in a while, long enough to get it to operating temp (I have mine set to run once a week for about 1/2 hour) to keep moisture from causing problems, and to keep the battery charged.
If it's got to run "RIGHT NOW" without warning, you may want to think about a block heater.
Other than that, a good grade of fuel and lube oil.
