Rust on tools
Bob
03-28-1999 05:09:41
I keep my tools in a Carftsman drawer tool box in an unheated building. With the temperature and humidity changes, I get light rust on tools. Any suggestions on how to prevent this problem. Thanks.
Arnold S.
03-28-1999 16:24:51
 Re: Rust on tools in reply to Bob, 03-28-1999 05:09:41
Put some dern oil on em or try using them some time.
WRS
03-29-1999 15:26:50
 Re: Re: Rust on tools in reply to Arnold S., 03-28-1999 16:24:51
Arnold, we are talking about quality tools. Not those "made in China" imitations that you call tools. Oil is for lubrication not rust proofing.
Arnold S
03-29-1999 21:39:13
 Re: Re: Re: Rust on tools in reply to WRS, 03-29-1999 15:26:50
You must be a dumb *!%*#?!%#**.
JRT
03-28-1999 08:07:03
It would take some time to spary them all, but I would use a product called Boeshield T9. It is sold as an aresol spray and was developed by Boeing for longterm protection for aircraft components. It leaves a thin waxy film if left on to air dry, and an even thinner protective film if wiped off. I started using it after reading several reviews of it in gun and boating magazines- and it works.
The other thing to think about would be putting a low wattage light bulb in the bottom , so it would slightly heat the drawers and the tools. This is the principal used with the "golden rod" devices sold for safes. If there is no place to put a light bulb for heat you might try looking for one of the thin stick on heat pads to use with reptiles. They stick to the bottom of the aquarium, and provide a diffuse source of heat. You could stick one to the bottom of the chest after adding some sort of feet to hold the weight and provide some space.
signman
03-28-1999 16:32:22
 Re: Re: Rust on tools in reply to JRT, 03-28-1999 08:07:03
I have the same problem with new tools in my tool sales truck. Can you give us some outlets that may supply this Boeshield T9. It sounds like a great idea. I end up discounting to many demo tools because I can't leep them in condition.
JRT
03-28-1999 17:33:48
 Re: Re: Re: Rust on tools in reply to signman, 03-28-1999 16:32:22
Grizzly Imports has it in their metalworking catalog. 4 oz part # G2870 is $5.95. 12 oz part #G2871 is $11.95. Its not cheap- but then neither are tools.
Their phone number is 1-800-523-4777, and open 24 h per day. In looking the above up in their catalog I found they have a web site at www.grizzlyindustrial.com. Have not visited it yet- but that is about to change!
