What to do about wagon that dogtrack
mel
03-18-1999 16:52:53
How do i go aboutrepairing wagons that dogtrack? problems could bein bent tongue ,frame or tierods.
Bob
03-19-1999 23:26:10
 Re: what to do about wagon that dogtrack in reply to mel, 03-18-1999 16:52:53
Mel, Check your distance from front wheel to rear wheel on both sides and compare to see if they are the same. If they aren't then you may have a bent center pipe. This can cause a wagon to dog track. Some wagons this piece can be removed without a great deal of trouble. Good luck, Bob
RickB.
03-19-1999 04:22:41
Adjust the tierods so the front spindles are parallel with the front axle (with 1/4"-3/8" toe in) when the tongue is perpindicular to the front axle. Then make sure the reach is straight, and the rear axle is parallel to the front.
