Tecumpseh engines
Wild Bill
03-14-1999 20:42:43
I'm thinking of buying a log splitter with a 6hp flathead Tecumpseh. I've never owned a Tecumpseh, most guys around here don't seem to like them. Any opinions? Thanks.
michael
06-11-2001 09:21:31
 Re: Tecumpseh engines in reply to Wild Bill, 03-14-1999 20:42:43
My tecumpseh lawn mower just died after only two seasons of mowing a 1/8 acre lot !! A flat lot at that... this mower lived the life of Riley and still died while still in its infancy. That's the only Tecupsseh I ever owned... -- Michael
martin - heres the deal with any engine
04-01-1999 11:09:54
Modern engines not the old cast iron ones..
The more you pay the more you get. The B&S and tecumpseh and kohler all have lower priced engines ...
You dont get auto shutoff if oil is low
Electronic ignition(harder starting)
Compression relief (easier pull starting)
higher quality metals
oil pumps - instead of splashes
The lower priced engines make life a little harder for you in general and you have to be a little more carefull with them - checking the oil more often etc, dont tilt them at too big an angle or the engine wont get any oil.
However, they are priced lower - and therefore are more available to more people.
I feel that the high ends of any of the lines are comparable.
The thing is you have to find your local parts dealer and see what he is comfortable with fixing and with parts.
Remember for most machines you can replace the engine later on with a different one if you want.
If I had the $$$ and I would get the better engine.
I had a tecumpseh on my chipper for 5 years and ran the heck out of it, my neighbor "borrowed" the chipper and promptly blew out the block....(he tilted on its side becuase he had a green vine wrapped around the chipper shaft(green vines by the way do not chip real well) and when he tilted it back he did not wait for the oil to drain back down and it blew....
Which of course he did not offer to pay for - but he had a chipper that did not work - so I got it working and "borrow" it all the time.
Martin
Paul
03-17-1999 19:21:17
Bill, I've got a 6hp Tecumpseh on an OLD Troy Built tiller. It starts the first pull in the spring and runs like a sewing machine every time. I've never changed the points, and I can't remember changing the plug either. (My motto is: if it ain't broke, don't fix it) I change the oil often to make up for my other bad habits . . . When I bought it I figgered it would blow up the first summer. I would recommend a Honda, but I have to admit my Tecumpseh has given good service.
Tecumseh
03-17-1999 17:09:30
If your looking for something that would last go with an onan they use oil pumps and filters on most models instead of using the crank to splash oil everywhere. I work on onans, kohlers, hondas, tecumsehs and briggs and the onan is the best quality. I would have to say the hondas would be second but their valves need adjusted often. kohlers blow head gaskets.
Bob
03-15-1999 16:43:46
I agree with most guys around there.They don't start fer crap and they don't last.
Tom
03-14-1999 22:43:01
I don't like them either.
