Pump rebuild
Chuck
03-14-1999 12:26:58
Rebuilding an old hydraulic pump which has ball check valves. These balls are .25" diameter. Could I use balls from a ball bearing? If so, what size ball bearing would have this size balls? Any help would be appreciated.
ronm
03-15-1999 07:08:17
 Re: pump rebuild in reply to Chuck, 03-14-1999 12:26:58
John Deere uses a .250 ball in a bunch of applications. The old part # was 400R, but I never memorized the new #. Any JD dealer should have several pounds of them on hand. Ron.
Dave
03-14-1999 22:36:51
Bicycles use loose balls. .25 is a common size for bikes so any bike shop can sell you them for a few cents. Good luck.
Bob
03-14-1999 16:56:34
Chuck, I think you can buy just the plain balls from your bearing dealer. I know I was able to buy .125 ball bearings for a bearing that used the loose bearing set-up. So give that a try first. Bob
