Converting unleaded gas generator to natural gas
paul boyd
03-14-1999 12:20:38
does any one know if there is a kit to convert a gasoline generator to natural gas?
TRUIDEMAN / GWENDEL
09-10-1999 05:07:40
 Re: converting unleaded gas generator to natural gas in reply to paul boyd, 03-14-1999 12:20:38
hallo would you please sent me information about leaded and unleaded gas.
Tecumseh
03-18-1999 16:04:39
call carb&turbo systems 1-612-445-3910 or
carb equip supply 1-214-351-0748
both these companies make conversion kits. If you ever want to buy a generator it's cheaper to buy the high watt one without the conversion and then do it yourself.
Tecumseh
03-17-1999 17:15:35
I work on propane buffers. Which have converted motors on them. Depending on the size and brand of your motor. I'm sure if you contacted the manufacturer they would lead you in the right direction. I would contact the motors manufacturer not the people who put together the generator.
Nels
03-14-1999 15:35:07
they can be converted to propane I suppose they can be made to run on nat gas too.
Bruce
03-15-1999 04:42:24
 Re: Re: converting unleaded gas generator to natural gas in reply to Nels, 03-14-1999 15:35:07
Natural gas has almost half the BTU's that propane has. It will run, but you need to DE-rate the capacity of the KW generator.
I don't know the address, but DYNA has tri fuel generators. Gas-propane & Natural gas & thats where you can find out how to derate the setup...
