Wow, someone else with a Greenbrier rototiller! Well, mine has a motor but I just broke something in the gearbox between the motor and the tines. I am now looking for a manual as well. Did you find any information on who was the manufacturer? I suspect that Greenbrier may be a trade name for another major brand name. On to your questions about the motor. My rototiller is a 5 hp. model. The horsepower of the motor is "advertized" on the handle, where the throttle and drive engagement levers are located. I verified the displacement and horsepower by consulting a Chiltons small engine repair manual. The motor is a 12.5 cubic inch Briggs and Stratton (B&S)engine. B&S identifies this as a 13 cu. inch motor. The motor appears to be their standard issue, with a horizontal crankshaft (small dual shiv pulley attached). The most complex part of the drive arrangement is the mechanism that transmits the rotation of the engine's crankshaft back to the large pulley at the "top" of the gearbox. The large "driven" pulley is located on the left side (standing behind the rototiller) of the gearbox. There are two belts that wind through this arrangement of pulleys, one belt engages when the drive control lever is placed in the forward position, the second belt engages in the reverse position. If you have this piece, you're lucky because I think that it would be very unlikely that you would find one anywhere. I hope that this helps. Let me know if a few pictures of the drive arrangement would be helpful. The installed position of the belts is quite complicated! I look forward to your reply... Ed Cassady
