As y"all know, I"ve been experimenting with welding cast iron lately... I recently used Ni-99 Nickel electrodes which worked great, but dang, were those things expensive...
I started looking for cheaper alternatives to nickel electrodes, and I found a product from Hobart called "Normacast" which is considerably less expensive... They cost around half as much and are easy to find as well, I bought the electrodes I used in this video at the local Tractor Supply, where I got 14 of them for around $15...
But the real question is, how well do they work?
I set out to find out... I dug through a scrap pickup I have, and pulled out a random cast iron exhaust manifold to work with, and set about my repair...
Manifolds are always fun to weld... They"re generally made from "lower" grades of cast iron, they suffer rapid and frequent heating and cooling cycles, and they"re "dirty" from thousands of miles of engine exhaust running through them...
Anyway, the particular manifold I found was white or grey cast iron... I "veee-d" out the imaginary crack, and drilled holes in the ends of the "crack" as well, to keep it from spreading, and set about welding it.
I followed standard Cast Iron welding procedure, and gave the manifold a nice preheat... Then welded, peened, welded some more, buried it in sand and let it cool...
And how"d it turn out? Quite well I"d say... There were no signs of cracks or other defects, and the weld ground down quite nicely as well...
I was really happy with how it turned out, and I was also pleasantly surprised with how well the normacast electrodes ran...
Anyway, here"s my video, it was really fun to make, and I hope you guys enjoy it... As always, have a nice week, everyone :) Audio/Video clip:video1
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to Lanse, 04-03-2013 09:36:03
You post vids then you blow outa here without even reading any of the responses anyway. Last time I asked you if the Nomacast [Not Normacast] rod had an AWG number and got no response.It is fine you make money off your vids but at least read the responses. I also still don't see a 20 lb fire extinguisher anywhere in the background.
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to dr sportster, 04-03-2013 10:55:29
When you see his name on a post....go to the next one. Don"t take his lack of response so personally. I get alot out of the posts and appreciate his willingness to share. There can"t be much money to be made on these vids.
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to SuperHank, 04-04-2013 17:02:50
If he took time to read the responses to his posting he would at least know how to spell the name of the welding rod he was using. As you can see, once again, he posted a video and then did not care to respond to anyones comments.
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to Sean Feeney, 04-03-2013 17:34:12
I welded for years in a concrete and steel building, even there we were required to stay in the area for a half hour after the welding was done for a fire watch. Some people are lucky, and sometimes their luck runs out.
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to JOB, 04-04-2013 05:03:23
Maybe I am paranoid, but I almost lost a building along with two vehicles from a welding spark. I was welding just inside an open garage door in a metal pole barn with a wire welder. Wife called me in for supper, and while in the house I heard a loud pop which sounded like it came from the building. When I looked out to investigate, I saw smoke coming out the doorway. A spark had flew into a box full of rags (several feet away), and ignited. The loud pop was a spray can exploding above the rags - both on a metal shelf. I was able to extinguish quickly with no real damage to anything, and learned a lesson. I do all my welding outside now. Too many flammables in my shop, and I still vividly recall the incident.
Re: Tried out some Cheaper Cast-Iron Electrodes in reply to Fawteen, 04-03-2013 15:44:30
Well, he"s a ell of a lot better than I was at his age. come to think of it, He"s a ell of a lot better than I"am now. lol. Can"t see good enought any more.
Many times it's all left to the video and if I or anyone else doesn't want to, or can't for whatever reason watch the video the thread is nothing but a teaser.
