Electrician Needed!
David
03-06-1999 17:07:53
Just picked up a air compressor at an auction today. 1. How can I tell if the motor is 1 or 3 phase? 2. What is the difference? The current motor is 3 hp Under the phase part of the tag it looked like a 1 was punched over a 3? volts were 115/230. Its a big ole' thing takes two to carry very far. Only two wires were hooked up coming from the motor
David
03-08-1999 04:26:12
 Re: Electrician Needed! in reply to David, 03-06-1999 17:07:53
Would a ground wire just be connected to the case of the motor? It is a single phase by the way, thanks for the input.
Bob
03-08-1999 15:12:46
 Re: Re: Electrician Needed! in reply to David, 03-08-1999 04:26:12
Yup
Bob
03-06-1999 20:01:16
David,if you only have 2 wires coming from the motor,odds are its single phase.Also with a 115/230 volt tag suggests single phase.I have never seen a 115v. 3phase motor.A lot of times on the cover where the wires go into the motor there is a wiring diagrahm which should tell you how to hook it up.Hope this helps.
David
03-07-1999 05:37:45
 Re: Re: Electrician Needed! in reply to Bob, 03-06-1999 20:01:16
Thanks Guys I think you have confirmed my thoughts. I will hook it up and see what happens. The good part is that at the auction there was very little bidding cause they thought it was 3 phase, hope I proved em wrong!
DY
03-06-1999 19:18:26
Does the motor have a box of capacitors on it anywhere? It's probably single phase, as 3 phase takes 3 hot wires to work. Put a ground wire on it when you hook it up. Is it old enough to have brushes? If it was 3 phase, it would probably say 230-460 volts.
