Electronic ign.
chet
03-05-1999 21:38:26
We ran into this problem at work. On a Wisconsin VG4D2,which is similar to the 4cylinder power uint on some older balers, the electronic ign. will short out. To check for this problem, a test light will light on the positive side of the coil but will not pulse on the neg. side when engine is cranked. Disconnect neg. lead to coil and re-check for coil spark. If no spark chances are the ign. module in the distributor has shorted out.
