Convert comp. ratio to psi.
al
03-01-1999 20:17:04
Anyone know how to convert a known compression ratio to psi? AL
Bob M
03-02-1999 16:32:55
 Re: Convert comp. ratio to psi. in reply to al, 03-01-1999 20:17:04
Under ideal conditions (no valve/ring leakage, no heat transfer, sea level standard atmosphere) compression psi calculation is:
PSI = (Comp Ratio x 14.7) - 14.7
Ideal conditions are never achieved - actual gage PSI is always less.
al forBOB M
03-02-1999 19:48:34
 Re: Re: Convert comp. ratio to psi. in reply to Bob M, 03-02-1999 16:32:55
Bob, I have aJD G that reads 185-195 on the guage at electric start crank speed.
Do I have 14-1 not 10-1 as I cc'd the block,pistons,head,gasket?
Others claim to have 200-300 and they crank harder than mine or their starters are weaker. I have never blown a gasket in 4 yrs of pullin.
Thanks, AL
BobM for Al
03-03-1999 18:13:34
 Re: Re: Re: Convert comp. ratio to psi. in reply to al forBOB M, 03-02-1999 19:48:34
I'd go with your cc measurement. That equation assumes ideal theoretical conditions, error-free gage, etc. It looks nice on paper, but not much help in the real world - as you noted!
Bill Kapaun
03-02-1999 04:15:43
You really can't, because of valve overlap. You also have a higher percentage of blowby and possible valve leakage at cranking speeds.
