Fuel pump problems on fordson Dexta
Nils
02-25-1999 11:50:21
I have an Fordson Dexta from mid fifty's where I beleive there is a Perkins installed
The serial number located in the center of the left side of eng. block: G0280098D
Another number is located left side, bottom of the block: 2GKN1872
it is an tree cylinder engine with SIMMS Diesel pump mounted ser.no:SPE3A60S402
i AM LOOKING FOR DRAWINGS ESPECIALLY OF THE DIESEL PUMP, SINCE THIS WAS DISMANTLED WHEN I GOT THE ENGINE TO ME. I NEED ALSO CONTACT NAMES / NUMBERS TO BE ABLE TO GET SPARES FOR THIS PUMP.
My biggest problem so far is the general arrangement / function of the membran mounted on the rear end of the pump controlled by vaacum from the inlet manifoild. (it seems for me that this should regulate the fuel rack in the pump, but need drawings to be able to mount it correctly
on forehand thanks
Jack
03-01-1999 20:00:19
 Re: Fuel pump problems on fordson Dexta in reply to Nils, 02-25-1999 11:50:21
the parts manuals available from this site have all the drawings you need. They are good reproductions of the originals.
welder
02-28-1999 19:01:57
dont try repairing a diesel fuel pump unless you have a test bench to set it up take it to apump shop
jack
02-28-1999 23:15:00
 Re: Re: Fuel pump problems on fordson Dexta in reply to welder, 02-28-1999 19:01:57
You are very correct!
welder
02-28-1999 18:54:40
NILS
03-01-1999 04:00:07
 Re: Re: Fuel pump problems on fordson Dexta in reply to welder, 02-28-1999 18:54:40
tks your consern, but my profession is a marine Engineer, with specialication in Diesel engines, and the information is all i need to be able to handle the overhaul.
JJ
03-27-1999 19:04:06
 Re: Re: Re: Fuel pump problems on fordson Dexta in reply to NILS, 03-01-1999 04:00:07
Nils it looks like if you are that educated you wouldnt get smart with a couple of guys good enough to offer help, also with all that education you should know what the lines are and how to hook them up.
welder
02-28-1999 18:54:40
