Gaskets
Leonard
02-18-1999 14:14:31
I guess this fits under the general heading of tools: What kind of material should be used to make gaskets between a carburetor and the intake
manifold of a small gas engine (for example a B&S)? I have some 1/16" thick asbestos-free Amgauge high density gasket material, will that work? Or do I need to find something else?
Mike
02-19-1999 14:56:49
 Re: Gaskets in reply to Leonard, 02-18-1999 14:14:31
I've been known to use the front cover of a catalog for that application. The idea is to provide a semi soft filler between the faces which is not affected by the heat and/or material it's holding in or out.
The outside cover of a spiral notebook has also been pressed into service with very good results.
Hope this helps...
Milo
02-21-1999 17:35:13
 Re: Re: Gaskets in reply to Mike, 02-19-1999 14:56:49
empty out the cheerios box
Tom
02-22-1999 22:21:38
 Re: Re: Re: Gaskets in reply to Milo, 02-21-1999 17:35:13
Old Shoebox Cardboard is just as good.
Dave Fullmer (TN)
02-25-1999 22:54:52
 Re: Re: Re: Re: Gaskets in reply to Tom, 02-22-1999 22:21:38
I have used backs of writing tablets in an emergency, but now I keep a stock of gasket material that I bought at NAPA. It's not that expensive and I don't have to worry about deteriating gaskets anymore.
