Lincoln Weld Pak 155 Mig
Gary
02-16-1999 19:13:19
Does anyone know if you can re-wire the 155 for 110V. The Weld-Pak 155 is 220v and the Weld-Pak 100 is 110V. I have the 155 and it would be nice if it could be used on 110V or 220V.
fred
01-24-2001 11:34:53
 Re: Lincoln Weld Pak 155 Mig in reply to Gary, 02-16-1999 19:13:19
So where's the best (cheapest) place to buy a Lincoln Weld Pak? Does the Weld Pak 100 (115V) work as well as the 155?
Dunderbutton
08-26-2000 00:22:03
When I lay down after I take a shower I fart and since I'm naked it sounds louder and funnier so I giggle.
Robert Richins
03-10-1999 19:44:08
I know that Lincoln builds the 155 for Sears
and the Sears model is 120 volts.
fuck off
03-10-2000 00:25:23
 Re: Re: Lincoln Weld Pak 155 Mig in reply to Robert Richins, 03-10-1999 19:44:08
im building a class 1 desert buggie,, and I use the 155 for all my welding needs and it kicks ass
David Davis
02-19-1999 08:59:59
NO, the internal workings are 220v.
jack
02-18-1999 20:40:16
you probably could but you might then want to give it to your least best friend just befor you leave town...
