Henrob Torch
Doug T
02-09-1999 19:19:37
Has anybody had experience with the Henrob torch. I bought one last summer and cannot get it to burn properly. The book says during set-up that 4 psi of acetylene wide open w/no. 3 tip will burn clean. Can't get this to happen. Trouble-shoot says improper pressure. They claim this should happen w/o oxygen. When I add oxygen it backfires and burns in the tip. I have got it to operate with small tip and low settings, but also will not cut w/ cutting set-up. Co. tech line will not return calls. any ideas??
Roy Aspden
01-25-2000 09:38:12
 Re: Henrob Torch in reply to Doug T, 02-09-1999 19:19:37
I bought a HenRob torch at the ABANA conference in Alfred NY but have since moved to the NW. Does anyone know hwere one would get parts for this handy little item?
Cent
03-17-2000 21:31:20
 Re: Re: Henrob Torch in reply to Roy Aspden, 01-25-2000 09:38:12
members.tripod.com/~henrob2000/henrob.htm
Cent
03-17-2000 21:31:10
Roy Aspden
01-25-2000 09:37:35
I bought a HenRob tourch at the ABANA conference in Alfred NY but have since moved to the NW. Does anyone know hwere one would get parts for this handy little item?
Gene Gullo
03-08-1999 16:24:19
I just received the henrob 2000 the other day I cannot get it to cut clean. The molten metal flows back into the kerf. I tried to call the person I bought it from, located in Florida, but as of this date he has not retured by call.
Ron
08-19-1999 18:30:38
 Re: Re: Henrob Torch in reply to Gene Gullo, 03-08-1999 16:24:19
The instructions say that the oxygen delivery tip, (the copper tip) should be 1/16" from the surface of the metal. If you hold it higher it will try to melt itself back together and a lot of slag will form. Try schooting it across the surface, touch to 1/16" off the surface. It will cut great! Remember, for 1" metal, turn oxygen pressure up to 28 lbs, for 1/2" metal, 14 to 15 lbs, 1/4" 7 to 8 lbs.
JACK
02-10-1999 13:05:41
I BOUGHT ONE THREE YEARS AGO AND USE IT ALL THE TIME IT IS A GREAT TORCH IT DOES EVERY THING THEY SAY IT DOES FIRST YOU PUT THE # 3 TIP ON THEN OPEN THE ACTY AND OXY VALVE ON THE TORCH ALL THE WAY WITH THE REGULATOR ALL THE WAY OUT TURN IT IN TILL U GET A LITTLE PRESSURE AND LIGHT IT NOW TURN ACTY REGULATOR IN TILL THE FLAME STOPS SMOKING OR JUST ABOUT THEN OPEN OR TURN DOWN OXY REGULATOR UNTILL U GET A NUTRAL FLAME THAT SHOULD GET U IN THE BALL PARK MAY BE U CAN TURN IN BOTH THE REGULATORS A LITTLE BIT MORE BUT NO M,ORE THAN 1/8 TH OF A TURN NOW TAKE THE BIG TIP OFF AND PUT A SMALLER TIP ON AND DO SOME WELDING IF YOU HAVE A FREND THAT IS A WELDER HE MIGHT BE ABLE TO HELP U I HAVE NOT HEARD OF ANY ONE THAT HAS HAD TROUBLE WITH ONE BUT THAT DOESNT MEAN THAT WONT HAPEN WHERE ARE U FROM WHO DID YOU BUY IT OFF OF AND WHERE I`LL TRY TO GET YOU GOING BUT IF I CANT E-MAIL ME WITH YOUR ADDRESS AND PHONE NUMBER AND I WILL CALL YOU I KNOW A DEALER AND WILL CALL HIM FOR U
JACK
02-10-1999 13:05:08
JACK
02-10-1999 13:04:41
