Gempler's Rust Remover
Leonard
02-03-1999 05:00:55
Has anyone had any experience with Gempler's non-acidic Rust Remover? It almost sounds too good to be true. Does it remove "real" rust or just the thin coating of rust on a freshly ground piece of iron?
They have a web site Link
Mark
02-10-1999 18:12:07
 Re: Gempler's Rust Remover in reply to Leonard, 02-03-1999 05:00:55
I have used both the converter and remover. They both work very well. I have bought a number of things from Gemplers and been very happy.
John in Pa.
02-03-1999 12:22:58
Leonard, I used Gempler's Rust Converter on a 550 gal. oil storage tank with great success. Wire brushed the rough stuff first, then rolled the stuff on. It soon turned a dark purplish color then turned black. Used no primer...finished with Rustoleum paint.....good stuff!
Dave Fullmer (TN)
02-10-1999 19:11:06
 Re: Re: Gempler's Rust Remover in reply to John in Pa., 02-03-1999 12:22:58
This sounds like the stuff NAPA sells. I have been buying EXTEND from NAPA which does the same thing. The only thing I object to is that I have only found it in pint bottles.
Doug Spalding
02-03-1999 05:47:31
Leonard, this is one of those rare products that performs as advertised. Directions specifically state that you should not sand blast. The product works by bonding to rust and changing to a solid oxidized skin. What you should do is brush loose flaking rust off, dry the metal, make darn sure there is no oil and then brush or spray the product on. The steel should be fairly warm and should sit for 24 hours after application. After curing you can and should prime and paint. When used on the underside of vehicle or tractor it is a good idea to spray one of the rubberized undercoatings available in any auto parts store. I have used several gallons of the stuff on various applications and have been satisfied that it does exactly what it promises.
Leonard
02-03-1999 08:30:52
 Re: Re: Gempler's Rust Remover in reply to Doug Spalding, 02-03-1999 05:47:31
Was that the rust remover or the rust converter? I saw on their web site that they have both. In any case it is good to hear that it works.
Doug Spalding
02-03-1999 09:20:31
 Re: Re: Re: Gempler's Rust Remover in reply to Leonard, 02-03-1999 08:30:52
Converter
