Checking 2 cyl. RPM
Jim C.
01-31-1999 20:05:03
My automotive RPM meter doesn't work on my JD 2 cylinder. Anybody have suggestions as to what I might need. Thanks
Jim
03-07-1999 06:48:02
 Re: checking 2 cyl. RPM in reply to Jim C., 01-31-1999 20:05:03
An adjustable strobe light will also work but they are expensive.
chuck
02-06-1999 15:20:17
Mechanical tachs made by Stewart-Warner or AC can be ordered from most auto part stores, these will read speed of any exposed rotating shaft. There are also digital photoelectric tachs, try Snap On or Mac tools. Any shop that claims to work on Diesels will have a photo tach, it might worth while to take tractor to them or if the guys would be willing to bring tach to you and check speed for you.
Don
02-01-1999 18:25:04
Use a small engine wireless tachometer to check RPM at sparkplug, or find someone that has a thresherman's tachometer to check RPM on the pulley or PTO (pulley is the more accurate reading).
