Naval jelly on machined surfaces
JRT
01-29-1999 05:32:20
I am "restoring' a 1941 cylindrical grinder and have run into some gears ( 1 to 3 in diameter with small teeth) and ground and scraped ways with rust in some areas. I have not used naval jelly before, and was wondering if it would be appropriate with the above. My underatanding is that it is phosphoric acid, and reacts with the rust. I also know that it must be washed off with water, and the metal then oiled. Anything else I need to watch for? Will it etch the steel or cast iron?
Joe Fabregas
01-29-1999 15:40:40
 Re: Naval jelly on machined surfaces in reply to JRT, 01-29-1999 05:32:20
How heavy is the rust? Just a light bloom, little crusty, or down-right heavy? A tool maker friend recommended Noxon Metal Polish, it will remove the bloom but not the metal. Worked great and you won't need to go to the gym for a while. I used a scraper, very lightly, on the few crusty spots, then polished. I tried the jelly once and didn't care for it enough to buy more. Go to some auto shows this summer, they have liquid spray on, and dip that can be used over & over. They all smell like phosphoric and they will all etch if left too long. The cast will clean up nicely if not too bad, doesn't take much to pit steel, especially high carbon. If you don't have a scraper you can make one from a three corner file, hollow grind the end for about an inch or two, don't overheat. Drop me a line if you have more questions. I'd wire brush the gears and keep well oiled when breaking in, they should polish themselves. Good luck! Joe Fabregas [email protected]
