Thanks for the suggestions guys. I didn't want to try running a weld bead down the cylinder since those cylinders are so long and burning through could be diasasterous. I ended up making a sleeve puller on a lathe I just bought, made a full length plug slightly smaller than the piston with larger ring left on the cylinder to catch the sleeve. Then I used a peice of 4" pipe, a bit longer than the sleeve plug and used another machined peice that fit into the end of the pipe. Then I used a peice of 5/8 threaded rod and some nuts, and large wrench to pull out the sleeves. Making the rig took the longest time, pulling out the sleeves and pulling in the new sleeves took about an hour. My sleeves ended up being the thicker variety, so I had to return the sleeves I originally purchased and get some thicker ones. I don't know why this rig wouldn't work on the thinner sleeves also.Anyway if anyone wants to buy this rig I'd consider selling it. The whole thing must weigh about 50 lbs since the plug was machined out of a solid chunk of steel. Also the pipe was faced in the lathe so it is perfectly square and the pulling plate was also machined so it is perfectly square. I didn't want to pull the sleeves in cockeyed. As I said it should work to remove and install the sleeves from all 9N, 2N, and 8N tractors. Let me know if anyone is interested. Dave : : Guys, : : I need to pull the sleeves from a 9N tractor with the : : thin .040 sleeve. What do you recommend. Any cheap,effective : : sleeve pullers available? I've heard that they sleeves have : : a tendency to crush easily since they are so thin. : : One machine shop said that they bore them out. Seems : : a bit extreme to me. : : Dave : Dave, : I think those are removed by crushing them. They have to be replaced with a mandrel. I think some people bore their blocks out to use the thicker sleeves. My father-in-law has an 8N that has both kinds of sleeves in it. : Mike
