Ih cub
dan
01-25-1999 19:27:58
How is the snow plow installed on a 38 ih cub fARMALL
Ron Ossi
02-20-1999 20:12:12
 Re: Ih cub in reply to dan, 01-25-1999 19:27:58
It all depends on where you want to mount it on the tractor. The correct grader/snow plow unit for the cub can be mounted two ways (1) in front as a snow/dozer blade using its own mouting frame and cantilever lift arm or (2) between the front tires and rear tires as a grader blade by mounting the draw bar to the front of the final drive housings deleting the frame and cantilever off the plow and mounting the plow to the draw bar using the hydro-lift directly to the plow to lift the plow blade P.S. I'm looking for a complete set up for my cub so if you know of one for sale please let me know . good luck
