I managed to get hold of a prototype mini inverter machine. Runs on 240 vac 1ph, 140 amp max output @ 20% duty cycle with an input draw of only 20 amps @ max out. While the duty is limited, the arc characteristics are unreal. In a package 5.5" x 7.25" x 11.5" and weighing in at 6 pounds, I too thought this was some kind of joke...until I tried it. First bead was with a 3/32" 7018 and I could not believe how hot the arc was. Figuring it to be like the other mini machines, I set the amperage dial to 90 to start because normally the arc is not indicitive of the amperage setting on the dial. This one however, is nothing like the others. 3/32" 7018 will lay a perfect bead around 65 amps, 1/8" at 90 amps and 5/32" at 130. 1/8" 6010 or 11 run beautiful at a mere 60 amps. I questioned the lower amperage runs by consulting the company that built this prototype. The answer was because the power supply was an inverter type, the arc stability is much better than any other power source because the current and voltage can be controlled to very tight tolerances. Having an exacting control over the current and voltage means less voltage drop from the open circuit voltage to the running voltage. Higher running voltage output means less amperage needed. I recall from the old engine drive and motor-generator machines where you set the course current adjustment to a higher setting and kept the fine current adjustment to a low setting to get deep penetration with a "digging" arc, likewise set the course current adjustment to a lower range and cranked up the fine current knob to near max for a smooth arc. Inverter machines are nothing of this sort at all. You get the best of both worlds by having great pentration while still keeping a super smooth arc. I was even more impressed with this little inverter machine when I did some scratch start tig on stainless with it. Got a little spoiled with the HF start and foot control but could not complain one bit about how well the tig runs on the inverter. I got to love this machine so much, I could not help but get a bigger one, the Miller Phoenix 456. Great machine but I ran into some trouble powering it with a genset at 230v 3phase, arc became unstable and duty cycle was limited at the lower voltage operation. Whole reason behind this was being able to have the portable operation out in the mines and quarries or along the road while being able to plug the service truck into shore power when available. Since I am limited to 240v 3ph at the shop, I decided to scrap this idea in favor of the XMT-304. Smaller machine but plenty big enough for what I need. This one will operate on 240v 1ph or 240/480 3ph without requiring any wiring changes inside the machine, plus the inverter is designed to compensate better for the slight variations in input power associated with genset operation. I'm still driving the Trailblazer in the big service truck and the Bobcat in the small truck. As you can figure by now, I'm stuck on my "blue" machines. I've been using nothing but Miller since 1991. In addition to the above two, the Econotig, Millermatic 300, Dimension 452, 32 & 64 series feeders plus the 30A spool gun. Nothing wrong with the Dimension but I decided to replace it in favor of the XMT-304 not only because the XMT is an inverter but mostly because of the lower input amperage draw. The added plus is the 350 pounds less weight and better arc and no wiring changes to correspond with different input powers. I bring this up because I took note to you bragging a bit on Lincoln machines. In all fairness, my first engine drive was a SAE-300 with a Herculese 6 cylinder enigne. Needing a smaller more portable machine, one that weighed less than my pick-up anyway, I picked up an old DC 225 powered with the Onan twin 16hp. Ran this one for two years doing part time work until it blew a gasket and siezed before I could get it shut down. I was on a job an needed a machine right then and there, went to the local welding shop and there sat the Trailblazer ready to go, and, it did, right into my truck and off to the job site. Took a while to get used to the difference in arc between the lincoln and miller but I am glad I got the Miller. Last year was the first I ran a lincoln since that day I turned blue. I got called to a job right after ripping down the bobcat for its yearly complete service. The job was in a place where I could not get the big truck into but the guy said I could use his brand new ranger 8 that was there. He bought the machine mostly to use as a genset because he does not weld much of anything. I got there to find the machine all shiny and new with less than one hour on the meter. I used it, got the job done, but did not like it at all. The arc was sluggish and lacked stability. 1/8" 7018 vertical up's were nearly impossible to do with this machine. The arc was nowhere near the snappy hard driving Miller arc. A short time later, I was called in on a pipe job by another welding shop I work with from time to time. His pipe guy was hurt in a car wreck and he needed a job finished pronto. He had the Lincoln engine drive pipe machine (don't recall what lincoln calls theirs) at the site. I had to make about 30 joints on 8" sch80 pipe and fittings. I got into the first joint with 1/8" 6010 and played with the machine for about an hour before giving up. This one was much the same as the ranger 8 in that the arc lacked stability and seemed to just lay around instead of driving into the base metal. I finally fired up the bobact and finished the job without a glitch. I also had a bad experience with an Ideal Arc 480v multi-process machine at one of the coal plants. The guy was trying to be nice and bought this machine to leave in the plant for me to use. I hooked the first one up and it would not even run a 6011. The ouput amperage wandered up and down so much that you could not even maintain an arc for more than a few seconds. Thinking it was just a bad machine, I returned it to the dealer, got another new one and had the same exact problem. This one was also returned and yet another new one ordered. A week later, the dealer delivered the new machine and stayed for the hook-up and test run. This one was better but after running 5 or 6 rods back to back, it too got the wild amperage swings and uncontrollable arc. I'll say this much, the dealer tried to make things right and called the factory right from the plant office to find out what was wrong. A few minutes later he hung up the phone and said "I can't believe what they just told me. If they don't like, they don't have to use it." He did his best to try and make us happy but ended up giving us a full refund and taking the losses on shipping and his time. After that, I made a deal with the owner of the plant and my old Dimension is there now, which BTW, I will be using tomorrow. After these bad experiences with lincoln, I could not bring myself to compliment thier newer products in any way. I still fire the old SAE-300 from time to time when doing heavy carbon arc work but that's it. I can't complain one bit about this machine since it is still a great machine. It's big and sucks a lots of gasoline down but works fine. The new ones, I think, nuff said for my view of them.
