Penetrating oil ?
Bruce L.
01-20-2002 18:15:11
working on a 4 cly. flathead have 3 stuck valves and a piston or two have got the 4th valve unstuck been spraying 3 to 4 times a day since x-mass.
What kind of penetrating oil do you use ?
Can i put heat to the head of the valve with a mapp torch to get oil to the valve guides?
Nolan
01-22-2002 03:52:40
 Re: Penetrating oil ? in reply to Bruce L., 01-20-2002 18:15:11
My favorite is Liquid Wrench WITH TEFLON. Regular Liquid Wrench isn't worth a darn. I've used PB Blaster, Kroil and others with good results. The Liquid Wrench WITH TEFLON is better, imo. It's no better at breaking free a frozen fastener then PB Blaster is. But once the fastener has broken free, it far exceedes everything at keeping it going, instead of wringing it off once the threads jam with rust particles.
Franz
01-20-2002 23:55:05
PB Blaster. It's only about 2 bucks a can in case lots from the distributors, and it works better than the expensive ones like Kroil or Gibbs.
Glenn(WV)
01-20-2002 19:42:05
I like PB Blaster and Kroil.
bob
01-21-2002 06:13:13
 Re: Re: Penetrating oil ? in reply to Glenn(WV), 01-20-2002 19:42:05
when working at power plant tis fall we wanted some more kroil and can said we had to order direct now why I don,t know but did and had it next day so service was good I perfer it in gallon cans as have had trouble getting all out of spray cans run out of air
the tractor vet
01-20-2002 18:26:57
I perfer ZEP but PB balster is good
TP from Central PA
01-20-2002 18:48:07
 Re: Re: Penetrating oil ? in reply to the tractor vet, 01-20-2002 18:26:57
My father bought a case of "Gibbs" (Penetrating oil) at an antique engine show. Boy that stuff works beautiful, I think they have a website, do a search, I would definitly look in "Gibbs"!!!!! I use it before anything else, including PB blaster and Kroil.
Gordy MN
01-21-2002 06:28:47
 Re: Re: Re: Penetrating oil ? in reply to TP from Central PA, 01-20-2002 18:48:07
I found their website it is: "www.gibbasize.com" They do not mention the price anywhere, so it must be expensive. I have never heard of Gibbs, but wouldn't mind trying it if I could buy one can. Maybe you get what you pay for..... Gordy MN
P.S. Right now I use PB blaster.
