Tool Talk Discussion Forum
electrical advise for 10kv generator
Don Anderson
08-03-2009 08:59:00
I bought a 10kv military generator that is labeled for both single and 3 phase output. I want to be sure I am hooking up the power leads correctly for single phase 120/240 volt operation. According to the diagram there are four posts for output. L1 is for 3 phase operation only and for the setup I want you are supposed to hook the leads to L2, L3 and L0. Is L0 for the ground or neutral? I am not sure of the correct term? It also has a lug that goes from the frame to a grounding stake. Thanks for any help.
