Meyer Plow pump problems
Richard Fazio
01-14-2002 11:34:25
I got my self a used Dodge truck and meyer plow setup. The pump an E47, works ok but leaks like heck. It leaks from the joint between the power angle valve block assembly and the sump. I changed the seals betweent the two and it still leaks. I think it could be a seal somewhere else and it's just leaking down to the area between the two. Anyone have any experience here? I ordered a complete seal kit I was hoping for a little guidance. Thanks RF
Al
01-14-2002 19:47:55
 Re: Meyer Plow pump problems in reply to Richard Fazio, 01-14-2002 11:34:25
Check out www.plowsite.com.
Bill
01-14-2002 15:07:15
I'd check to see if there is any thing that is preventing a good smooth sealing surface. THere are a couple of good plow sites that you could check with. Do a search on snow plows. If you don't have any luck post again and I'll check my sources for some WEB sites.
Good luck
Bill
